Ratfur reattachment
Pod
Last seen: 11 years 3 months ago
Ratfur reattachment
Some of the ratfur on the cieling of my 92 Scamp has come loose (with the insulation).Does anyone know how to reattach it without stripping it all off?
debstaines
debstaines's picture
Last seen: 1 year 1 month ago
3M adhesive spray
I had the same issue.  I just plled it back a bit and sprayed the roof side, then smoothed it over the adhesive.  if it's a big area, just do a little at a time.  Mine is still stuck a year later
wear a paint mask of some type, it's pretty smelly stuff.
good luck
Deb Staines
2016 16’, layout 4
'Rapscallion'
3M 77 adhesive
I also use the 3M 77 adhesive. Spray both surfaces wait about 30 seconds then press together (like contact cement). Some claim it releases in extreme heat but I have not had an issue with that. To reattach your satfur trim strips use a hot glue gun. The 3M 77 can be bought at the big box stores, even my local Wally World sells it.
