Black water tank capacity question
Tom in NM
Last seen: 13 hours 58 min ago
I've only recently started using the black tank on my 13'.  There is a circular opening (3" ?) visible below the flush opening to what I assume is the black tank. I was dumping when the liquid got to that level but far less drained than I expected, certainly not 9 gallons.
Am I correct that much / most of the 9 gallon capacity is actually in the pedestal, not the black tank itself? If so, at what level do people dump?
Last seen: 3 days 16 hours ago
Black tank video
Most of the nine gallons will be in the tank that is in the wet bath.This is an old video but I think that the black water tank is still the same in yours. (Start at 50 seconds)  https://www.youtube.com/watch?v=Sym4o0yKUtQ
Tom in NM
So the pedestal tank?
Thanks. I've read the manual (didn't realize there was a video version). My question was the volume of the lower black tank versus what I was calling the pedestal directly under the toilet. When you say tank in the bath, is that what you mean?
Yes...
...that square-ish tank in the wet bath is the black water holding tank.
K
Tom in NM
Smaller lower tank
Again, thanks. I think I now understand. What seemed like an outlet to a lower tank is in fact just the outlet pipe to the dump valve. The black tank is in fact what I see in the bath. Correct?
WOW! No pictures.
I was going to post a picture but I can not find one, not even on the Scamp parts web site. But yes you are correct.
K
