window malfunction
HappyScampersJi...
window malfunction
Hello everyone! New to SOI and have a problem with the window above the stove on our 2015 13 Scamp. During a recent Scamping trip the window was very difficult to close and left arm of the closer bent. Upon close examination we noticed the little wheel that slides back and forth during operation was broken. Any suggestions on repair or relacement?
Hehr parts
http://rvwindow.com/RV_Products_List.aspx?CategoryID=199
    This site sells the Hehr torque arms/operators. I'm guessing you need the small one. If these don't look like what you need you may need to pull out the window to get to the data tag info. Usually the little wheel break apart and cause the window to jam or separate from the arms.
If it is a 2015 it should be a warranty issue. But at least you should know what part you need.
