Order Placed for 13' Scamp... Can You Help?
25 posts / 0 new
Scamper Campers
LED lights
Whe we picked up our new 13 footer, LEDS were not available installed.  We bought the LED bulbs that  were available at the parts store and installed them before we left the factory.  We installed them at the factory just incase there was a polarity issue.
BobH.  one of the Scamper Campers
365vacay
365vacay's picture
Good Call!
Do you know the bulb style/brand/model that you use? I would like to research LED bulbs.
Kevin
Countdown to Fulltiming... Jan/Feb 2017
http://365vacay.com
Last seen: 3 years 12 months ago
LED Light Bulbs for Scamp
Under the Resources Tab, at the top of the page, is the  "Solar for Scamps" section. If you read through Step Two, you will find all the information you need about LED Bulbs. You can also read everything you need to know about choosing Solar Panels and the benefits of Portable vs Fixed panels.
Also, (in response to another of your postings) you might want to read "Buying Solar -- One Man's Journey"
  http://www.scampowners.com/forums/buying-solar-one-mans-journey
This might help you decide about the Portable Solar Panel you are considering.
365vacay
365vacay's picture
Kevin
http://365vacay.com
I get my bulbs at ham radio
I get my bulbs at ham radio festivals. I get 12 bulbs for $5.00!
365vacay
365vacay's picture
Thanks Doug!
Thanks Doug!
Kevin
http://365vacay.com
carl
Scamp sells led bulbs on
Scamp sells led bulbs on their site.  Carl
Get the Fiama F-45 awning for
Get the Fiama F-45 awning for SURE!
365vacay
365vacay's picture
Thanks for the suggestion.
In an effort to keep my tow weight down, I opted to forgo an attached awning.
I am going to keep a 6x6 pop-up awning and use it as needed. Thoughts?
Kevin
http://365vacay.com
Last seen: 6 hours 26 min ago
Clam Shelter
I would highly recommend going with the clam shelter recommended in this post.
http://www.scampowners.com/forums/clam-1660-sale-0
Way better than any of the portable shade devices out there.
Just FYI, the awning weight whether attached or carried will still count against your tow limitations. A clam shelter will be lighter than an attached awning for sure, but still goes in the total.
