Brake controler
21 posts / 0 new
RE: The people that recommend adaptors for hooking a seven-pin .
RE:  "The people that recommend adaptors for hooking a seven-pin trailer cord to a 4 pin Tow vehicle have no idea what they are talking about. It only gives you lights to get it home. "
Times change.  You might want to take a look at the brake controller that was specified and specially the wiring diagram. The AuTOWbrake controller mounts on the trailer and gets its power from the trailer battery as well as the brake signal from the brake / turn signal lights wiring. Since the brake and turn signal lights can or do share the same bulb and wire, it must be that the AuTOWbrake requires that both be lit at the same time so that it knows it is a brake signal and not a turn signal (wonder what happens if you have the four-way flashers on). It wires into the trailer wiring, not directly to the tow vehicle wiring.  I do see a possible problem if you have a discharged trailer battery and also no charge line. In that case I can see that the trailer brakes would weaken or fail altogether. Therefore I would want a charge line also. They seem to allude to using the running lights circuit for power but that might overload the tow vehicle's running lighting circuit. Also I don't like the keyfob for manual brake activation.  However,the plus is that this brake controller needs little or no modification to the tow vehicle.
Last seen: 1 month 1 week ago
Controller / adapter
Controller yes, adapter no. Trailer brakes and trailer brake controllers are two different things as well.
Words mean things.
Lola
Adapter
I understand where you are coming from with your comment but perhaps I did not explain well.  It is true the adapter only allows the car to indicate turning signals, running lights, and brake lights.  The trick is that the brake controller is in the camper and when the brake lights signal the controller is engaged.  Beyond that I do not understand exactly how the brake controller works, but I know that it does.
Lola
AUTOWBRAKE
Yes the AUTOWBRAKE ($350) Run the brakes, but the adaptor that auto parts stores sell for $10 called for above will not. And what powers backup lights, and the 12 VDC to the Scamp. The parts stores are very happy to tell the new RV owner that the adapter is all they need.
Lots of people have neither a
Lots of people have neither a charge line or back up lights wiring for their trailer and they get along just fine. So their need might be met if they don't need those things.  I dont have back up lights. I do have a charge line but do not need it and if the fuse blew I might not even notice.
And with the AuTOWbrake they don't need to tap into the brake pedal switch, or the wiring harness in the tug (if there even is one), or connect the charge line (but I as I said, I would).   So its a possible solution for some (like Subaru owners) but I prefer my P3 wired solid into the tow vehicle.
Lola
Scamp installed trailer brake
The people at Scamp are going to put on the trailer brake controller on the 13’ camper we will pick up at the end of April.  It just seemed easiest for us.  The parts gentleman at Subaru told us that the hitch will be a flat 4 prong and we will need to get an adaptor from the auto parts store for about ten dollars.  Fingers crossed that all goes as we have been explained.  I would be happy to report back after we have picked up the Scamper Camper!
Lola
Galleta'sDad
Galleta'sDad's picture
I like this idea! I have a 2016 Subaru Outback..I won't be picking my Scamp13 up until October. Keep us informed how it goes please!
dhelgeson
dhelgeson's picture
Last seen: 2 years 12 months ago
Tekonsha brake controller
Brakes are squeaking, what number do you tow at. Im towing with a Nissan frontier 4x4 crew cab. I towed my 13 scamp at 6.0(power knob) without a problem. Trying to pull a 16, its squeaking and I'm wondering if its the wrong setting or bad brakes? What number do most 16's need to be towed at? The trailer is about half the weight of the tow vehicle.
Larry Nordell
Electric brakes
I bought a 2007 Scamp 16 last year and the previous owner (who was not the original purchaser) told me it does not have electric brakes, so I did not get a brake controller when I had my Sienna wired for the trailer connection.  Did they all come from the factory with brakes?  Or was it an option?  Is there an easy way to tell if it has brakes?
Larry Nordell
You can see if it has brakes
You can see if it has brakes by looking at the inside of the wheel / axle.  If you do that, but don't know what you are looking at, then post pictures or take it by a trailer shop and ask them.  If there is a backing plate for mounting brakes, but no brakes, then you can add brakes.  See:  https://scampowners.com/forums/trailer-brakes#:~:text=If%20your%20axle%2....
I have a Sienna, and if I had it to do over again, I would use a so-called "wireless" brake controller.  While I prefer hardwired, it is not easy to install one on a Gen 3 or prior Sienna.  A wireless controller still requires some wiring. but not as much and especially you do not need to tap into the brake pedal wire.  The Sienna still needs (or should have) a lighting interface.  The one I used requires pulling off the tail-light assembly... a bit scary if you have never done it before because it looks like it will break in the process.  Then plug in the adapter, run the wire to the other side, pull that assembly off and plug it, and run power from the battery (IIRC).   The Sienna takes a lot of work to get set up for towing.
On my Sienna I ran the wiring for a Tekonsha Prodigy P3 under the van, and through the engine compartment firewall.  Working on by back with the low clearance was a pain.  Securing the wiring in a safe way took a lot of effort.  But it worked well for years.  Then I had to have a recall done on the van in which they needed to remove the entire dash.  There is no way the dealer would also maintain my after-marketing brake controller install, so I removed everything before taking it in for the recall work.   Then I had to reinstall it all over again.  This time I chose to run the wiring through the interior.  Still a lot of work.  A "wireless" controller would have been easier.   A tow vehicle pre-wired for a brake controller would be better and my next vehicle WILL be pre-wired from the factory.  Photo of my work in process for the second time install of the brake controller:
