Help! Water leak under shower insert
WS56
Last seen: 3 months 1 day ago
Hello,
My wife and I just bought a 2001 16' scamp (layout 6 I believe). I just replaced the black tank in the front and I think I hit a water line when replacing the screws holding the tank to the floor. When I tested the water this morning water came pouring out under the front of the camper, from the hole for the shower drain and from the edges where the subfloor meets the shell.
Is there any way that I can get away with not pulling out the shower floor insert to let the subfloor dry? I think I can fish some new water lines to fix the leak but I'd rather not pull the shower insert if I can get away with it. Any suggestions or insights are welcome, (even if I just need to buck up and pull the insert so it can all dry properly).
Thank you all in advance!
