Replacing door lock
35 posts / 0 new
Last seen: 1 month 4 weeks ago
This doorlock and hinge?
Just one I grabbed from the internet.
Last seen: 1 day 4 hours ago
Video
It is in this video about 12 minutes in
https://youtu.be/s-qvd74DHn0
JDHaggerty
JDHaggerty's picture
Scamp door lock
I forget where I saw the original instructions, but I added this Fastec FIC brand lock back in 2014 to our 05 Scamp 16'. Although mine is a manual key lock, you can also get electronic locks that would fit in the same footprint.
Made a template before I cut the larger opening, and removed the old latch since it would not line up with the new lock.
The new latch is just a 1.5" wide flat aluminum bar, cut to the size I needed, bent for the 90 degree angle in my workbench vise, and backed up with a piece of wood on the interior for extra strength. I rounded the edges with a file so they wouldn't be too sharp.
I really like the newer lock, and the deadbolt is an actual lever you can easily find in the dark, instead of trying to poke a pin in a hole in the dark like our old lock.
04 Dodge Dakota Quad cab 4.7
17 Dodge Durango 3.6
Hoosier Scamper
Hoosier Scamper's picture
Last seen: 7 months 1 day ago
Related Keyless lock
I posted replacing this with a keyless lock earlier this year, The hole on the new flat door is a standard hole. 3.75" x 2.75" and 1.5" deep...
https://scampowners.com/forums/keyless-entry-handles
Carl
