Bearing service
Tom in NM
Last seen: 1 week 5 days ago
Bearing service
Hi folks,
I have a 2021 13'. First trip was ~ March 2021. It's now been nearly 3.5 years and the trailer has some 10,000 miles or so on it. The bearings have not had any maintenance. My bad. I've not noticed any issues and have not noticed any excess heat from the wheels. I do check when I stop, but have not specifically done the "touch the hub" routine mentioned in other posts.
Should I have the bearings inspected and repacked or would simply greasing them likely be sufficient. I understand no one can answer that definitively. I'm just asking about others experiences. It's a pretty light trailer.
thanks!
Tom
Edit: after reading more, it seems I should these inspected and repacked. Some say every year but no one says it might be okay after more than 3 years!
I checked with two local shops. One says about $220 and the other said over $300. New bearings would add about $50 at the first shop and closer to $100 at the second. Guess I'll be going to #1. Both were recommended to me.
Mustangcats
Bearing service
I had the bearings on my Scamp 13 repacked this year at the local tire shop in my town for $90 plus tax.  As I recall, Scamp recommends a couple pumps of grease in each bearing every 5000 miles and that they be inspected and repacked by hand every 12,000 miles.  Whenever I stop for gas, I walk around the Scamp and carefully put my hand on the hubs to check for heat.
Tom in NM
Great tip
Thanks for that input. I will check with my local tire shop where I've done business before. That's a lot less than these trailer shops are quoting!
Tom in NM
Bearing replacement
I'm considering repacking these myself. I've done bearings on cars in the past. Doesn't seem to be any different. Couple of questions in the unlikely event that I need new bearings.
1. Many videos show people replacing bearings but not the races. My recollection that we always replaced both as a set even if the race seemed fine.
2. In others experiences, is it worthwhile to have a full set of bearings on hand or are these sizes so readily available that isn't necessary? Scamp told L44649 & L68149. I see sets like this online.
Trailer Axle Bearing Kit L68149/L68111 L44649/L44610 Grease Seal 171255TB 10-19 I.D. 1.719'' for #84 Spindle 3500 LB Trailer Axles (Set of 2) https://a.co/d/4VCc31e
3. Any strong feelings about bearing brands?
Tom
