Gray Water Sink Drain Inlet
BTCarr
Last seen: 1 week 2 days ago
The barb for the sink drain input to the gray water tank broke off.  I have been looking for what part I need to fix this but cannot find anything.  Does anyone know what part I need?
Last seen: 3 weeks 2 days ago
This trap?
https://www.scamptrailers.com/product/sink-trap
Or do you mean at the tank? For that I would call Scamp, The new tanks come with three, but I do not see them listed in the parts list on line.This is all that I can find.  https://amzn.to/45uTMPF
BTCarr
Sink Drain Grey Water Inlet Repaired
Here is the issue I am addressing:
I did call Scamp and they did not have any information on that part except to replace the tank.
Initially I tried to move the drain hose to the vent hose position.  Tis way I could use the sink but would just have to mind my gray water tank level.  In doing this, I broke that one off also.
After much searching at hardware stores I came up with a solution.  I found that a 3/4" CPVC fitting (PN CPBDFA34W) would fit perfectly over the whole stub that was sticking out.  Using some PVC glue, I glued it onto the stub.  This left me with a MIP fitting to attached the hose barb onto (Everbilt PN A-590).  I then had a new barb to fit the hose onto. Here is a photo of them repaired.
Thanks for the follow up
This may help others with the same problem.
BTCarr
Pictures
Looks like the pictures didn't load.  Thought I did it right.
