Closet Mod
14 posts / 0 new
marthadoug
Last seen: 10 years 12 months ago
Did you remover the original
Did you remover the original closet or just expand the opening?  (I can't tell from the pix).  How did you keep fiberglass dust from getting all over the place?  Love the bins!  Very creative! Hope we can do this too
debstaines
debstaines's picture
Original closet
same closet. Bigger opening. It is just wide enough for the Trofast frame to fit thru and about 11" taller. All of the additional length is at the bottom, no cut at the top edge. If you are cutting, use masking or painters tape to prevent splintered edges. There will be fiberglass dust everywhere. Where a mask. I had one, my dad (doing the cutting) is "old school", but where a mask. I took everything out if it and then vacuumed the heck out of it. Walls too (I have rat fur). After you cut it there is an area toward the bottom that is double thick. I filled the gap with spakle then sanded the entire edge all the way around until it was smooth (mask and vacuum again). Then I very carefully painted just the edge with semi gloss paint (egg shell color). The edges are smooth and the paint matched the gel coat so I did not need any of that plastic trim they use. Of course you will need to make a bigger door
Good luck. Have fun!!  I LOVE my pantry!!
Deb Staines
2016 16’, layout 4
'Rapscallion'
Jaye580
Jaye580's picture
Looks Great
Nice work!
http://jayes2scamps.shutterfly.com
Previous eggs:
198? 13' Casita
1984 13' Scamp (layout 1)
Current eggs
1978 13' Scamp (layout 1)
2016 13' Scamp (layout 2)
