Patching closet screw holes
11 posts / 0 new
Tom in NM
Last seen: 3 weeks 1 day ago
I am making new cabinet doors in my 13' and expanding a couple of the closets in the process. The doors and storage areas in that narrow cabinet next to the bed are taller in the new models. I'm doing something similar. Because the doors are taller, I'll need to relocate at least two of the hinges. That will leave screw holes in the fiberglass. Is there a way to fill those to match the existing fiberglass, or at least come close? I know very little about working with fiberglass. Suggestions and comments would be very much appreciated.
Patching satisfactorily with fiberglass would be very difficult. I suggest plugging the holes with rivets (white ones are available). Simple fix (I have done this.)
Tom in NM
Thanks for rivet idea
Thanks for that suggestion. I've looked at some videos about patching fiberglass and it is quite a process for just these little holes. Since I'm making the cabinets larger, ie, cutting a larger opening, I've thought adding a stiffener inside along the sides might be a good idea. I could use the rivets (or small flat disk machine bolts) to attach a wood or metal strip. Thanks for the idea.
SAugust
Patching closet screw holes.
I've just used caulk to fill the holes.  Hardly noticeable.
If the white is too white, maybe you can mix in some almond or brown colored caulk to match better.
Tom in NM
Caulk
Thanks. I'll try that. I find many things are so evident while one is working on them and then quickly fade from view once the project is done.
DowneastME
DowneastME's picture
Last seen: 1 month 3 days ago
Late to the party, but I
Late to the party, but I recommend using a two part epoxy product called Marine-Tex in white.  It results in a very strong bond with fiberglass and has the same appearance.  It can also be sanded and painted if needed.  I've used it to make repairs on my Scamp as well as on fiberglass boats.
Tom in NM
Off-white
The brand I tried (see other reply) is Nanoxa. I did a test with a piece of internal fiberglass that I'd cut out. It did a nice job of filling the holes and sanding smooth. But it's more of an off-white so the filled holes are still quite noticeable. Before I try the Marine-Tex you suggest, I wanted to confirm that it is indeed the more pure white inside Scamp.
Tom
DowneastME
off-white
Yes, it is the same white as fiberglass.  Just make sure the box specifies "white."  Marine-Tex is also made in a gray which is commonly sold at marine hardware stores.
If you have to sand to level it, it may appear flat rather than glossy.  If you're concerned with that level of detail, you could apply a very small amount of clear nail polish (or similar).  I used it to repair a rear corner on the exterior of my Scamp where someone had dinged and fractured the fiberglass gelcoat in a parking lot.  I sanded it smooth and it matches the exterior almost perfectly so as to be unnoticeable. Good luck!
Tom in NM
Not too late - thanks
Thanks for the suggestion. After watching boat repair videos, I thought this could be a good solution, especially since these are small screw holes. I tried some caulk but would like something that blends better.
I did purchase a different brand - Nanoxa -  of the white epoxy (same mixing) but haven't tried it yet. I wonder if it's any different from what you've been using.
Thanks again for the suggestion.
Tom
Last seen: 19 hours 43 min ago
Marine-Tex
I did some patching on our '06 with white Marine-Tex.  Happy with it.
Tom in NM
Sanding
I tried the other brand I had already gotten and ran into problems with the sanding stage. This was on a scrap piece I'd cut out when enlarging the cabinet. Even fine sanding dulled the gloss finish around the hole. Did I do something wrong? Would the Marine-Tex be any different?
Per another suggestion (using white rivets) I found some #6 white headed machine screws and tried those. It doesn't look bad. Once you quit paying close attention, even the off-white caulk looked okay. Still, I'd like to know how to do it right.
