Replacing weather stripping around door
65 posts / 0 new
Last seen: 7 hours 42 min ago
Good One
laugh
dmoritz2
Weather stripping
same question, flap in or flap out?
D. Moritz
dmoritz2
Did you get an answer?
D. Moritz
debstaines
debstaines's picture
Last seen: 10 months 1 day ago
No but I figured it out
flap out. Looks and works great!
Deb Staines
2016 16’, layout 4
'Rapscallion'
dmoritz2
thanks no did you cut to fit
thanks no did you cut to fit or made on continuous loop?
D. Moritz
debstaines
Door seal
i started at the bottom on one side and went all the way around to the bottom in the other side. I used a standard foam type self taped weather stripping across the bottom, not the door seal
Deb Staines
2016 16’, layout 4
'Rapscallion'
dmoritz2
Door sea
Thanks for your help. Started to remove adhesive and what a job. I assume you mean flap outside toward the camper body?
D. Moritz
debstaines
Yes exactly
seal flap in the outer edge. Toward the body. Away from the opening. So the smooth corner right up against the door opening trim. I used goof off to get the old glue off
Deb Staines
2016 16’, layout 4
'Rapscallion'
dmoritz2
door seal
Help! Help! After spending 3 days getting the old weather stripping off the door, I put on the new seal and guess what the door will not shut??  What is the problem?  Any suggestions?
D. Moritz
flytyer01
Door Seal
Can you send a picture of the seal install and the door?
