Mini-Dinette Modification for Scamp 13' with Big Bed
14 posts / 0 new
This mod allows you to quickly and easily set up a two-person mini-dinette while still having a single bed 34" wide available.
And of course, the big bed and main table can still be set up exactly as before.
It uses the existing Scamp 20" x 30" bed board, Scamp cushions (modified), and a removable RV/marine table leg and base system. Adding only about 3 pounds, the leg and base system used was the ITC “Redwood” model TL 5000-B-29. It's available at ITC-US.com or Amazon. Scamp also has a leg and base used in their 16' dinette that should work.
Step 1: To switch from big bed to mini-dinette, fold back the bedding from the front 20" of bed onto the 34" of bed space left. (Note to those who have extra cushioning on top of Scamp's 4" cushions: We cut our egg-crate topper down the middle to be able to stack one piece on top of the other.)
The two center cushions modified were new ones purchased from Scamp, which are from a deluxe 16' layout B trailer. The cushions have one 34" section and two 10” sections to accommodate a curved wall in that model. For seat backs, we use the two 10" sections, keeping them attached to each other, but cut from their respective 34" sections. Velcro sewn on a flap attaches to Velcro sewn onto the adjacent 34” cushion.
Our original big bed cushions (with two sections, 44” and 10”) could have been modified by cutting the foam and doing the upholstery work.  However, we opted to buy the whole cushions from Scamp and just do the Velcro modification.
Step 2: Detach each small cushion set from the center cushions and place in the seat back position on both sides. Set aside the 20" x 30" bed board.
Step 3: Lock the table leg into the newly installed base with a quick turn. Snap the 20" x 30" bed board onto the table leg, and it's ready!
The board rotates freely, making it easy to sit down and position the table as desired.
WARNING: When installing the table leg base, the pilot holes and screws must not go through the floor and penetrate the gray water tank directly underneath. Our Scamp's floor is 5/8" thick, plus the vinyl flooring. We used #12 x1" stainless oval head coarse thread screws, and ground off 3/16" to shorten them. Coarse threads are best for wood; fine threads are for sheet metal and will strip in wood more easily.
This is the plastic table leg receiver installed on the underside of the 20" x 30" bed board. It's attached with #12x1/2" stainless oval head course thread screws.
Viewed from beneath the main table, the new mini-dinette table leg clips for storage into two white plastic clips fastened to the table's underside to the right of the fold-down leg. (Uxcell 50 mm diameter PPR U-shaped pipe clamps, available on Amazon.)
yes
theremin
Last seen: 1 year 12 months ago
That's a great idea!   Dave
Dave
Thanks Dave, we've been
Thanks Dave, we've been trying to figure out how to have a table without making up the whole bed ever since our first trip!  smiley
mengualj
mengualj's picture
Love this idea
We love this idea and it's a perfect solution that we are going to try. We feel like Scamp will catch on and maybe make it as an option to buy. WOW great idea!! We will let you know how we fo.
Robin and Joe
Joe and Robin
Thanks, it's very handy --
Thanks, it's very handy -- Just used it this morning for breakfast.
I wouldn't be surprised if Scamp eventually makes it an  option.  They know of it, wife sent them an email and talked with them about the dimensions of the cushions she ordered. Very nice to deal with.
First trip with mini-dinette
Just back from a 10 day trip, first trip with the new mini-dinette mod.  Quickly set it up every morning, and if we weren't traveling that day, it stayed up until evening.  Zero problems, a big improvement for us!
smiley
mengualj
mengualj's picture
We Made one too
Joe made one, too, minus the cushions. Thanks to your information. We just use the cushions we have. Joe did the table in no time. Joe ordered from amazon-Link below
Amazon Table mount
Using 2 black mounted bases-one under table and one on floor. Table can swivel to sit down. We keep the leg in the closet.
We love it and we're so thankful to you for the idea. And we were thinking the same thing about Scamp.
Happy Camping. Heading to NC in two weeks.
Joe and Robin
Thanks...
Thanks for the kind words, glad it was helpful laugh
Pics not showing up...
Does anyone know why the pics in post #1 above are not displayed???
kmkayak
Test for adding pictures
Hello Mr T,
I'm not sure why your pictures aren't showing, but I'm very interested in seeing them.  I'm doing a test post here with a shot of my new-to-me 2014 Scamp.
OK it worked, but it took some work - had to save it in <3 MB, then it took a while for it to load after I hit 'insert'.  Not sure if that helps...
KMK
pics that were visible are somehow not anymore
I'm hoping an admin here can fix the issue. They displayed fine for over a year!   Other pics from me are blank too.  Never saw a reply from any admin either.
