Front Stabilizer jacks
Crappie99
Has anyone added (or used) jacks at the front end of a 16' Scamp to stabilize it.   Our Scamp rocks quite a bit when walking inside, and am considering using removable jacks OR attaching them to the frame near the front.
Comments ?
yes, i bought these from
yes, i bought these from amazon (link below), i use one on each side, in tandem with the back jacks there is 0 movement in the scamp (i'm a large 240 pound dude, so that says a lot).  they are rated for 5000 lbs., so in the event of a flat or other issue, they can be used to lift the car/trailer as well.  i've had them well over a year now and don't have any issues with them.  the hand crank is what i use, works fine.
https://www.amazon.com/5000lbs-Stabilizer-Leveling-Mounting-hardware/dp/...
Tom in NM
Last seen: 1 day 15 hours ago
Stabilizer jacks
Old thread but thought I'd ask. Did you attach these or just place them each time?
