No water from hot water tap
13 posts / 0 new
Last seen: 1 week 2 days ago
Water Heater
You should have a mfgr/model # tag on there somewhere and the same model may still be available for a direct replacement.
I.E here are the Suburban RV water heaters on Amazon: https://amzn.to/35fhikG (SOI sponsored Link)
It should be a 6gal water heater just need the specifics of what is in your Scamp as they do change over the years.
Rarely
Rarely are RV appliances exactly Plug and Play but there is a Brand and Model number on the inside of the door and If you can find one on line with that number it may ease the install. The manufacture may have a retrofit page if you contact them.  . Simple things like where the gas line or water lines  comes in can be difficult if way different. . Our 2019 13 came with some minor sheet metal mods( trimming Grinding )  behind the door to make The door close better with the curved Scamp. I do not know if this is necessary. Others here are better versed on this I am sure.
