MaxxFan Issue Resolved
peaceandlove
peaceandlove's picture
Hello all:
Our MaxxFan finally lost its mind up in Michigan's U.P this past week.
We were dealing with the "green light of death" issue by removing and reinserting the fuse, which we had to every time we wanted to use the fan. Tedious, but doable.
But then the fan started to turn itself on while we were traveling, sometimes the vent cover would open, sometimes not.
The final incident before complete failure was when the fan turned itself on, chirped every so often and emitted a high-pitched, 20 second wail. None of the buttons worked; the fan was completely inoperative. The chirping continued!
To maintain our sanity we pulled the fuse and did not reinsert it, which resulted in the interior camper lights being inoperative due to poor electrical design on the part of Scamp which has the fan and the interior lights on the same fuse.
My husband rewired the fan to bypass the failed circuit board. The fan is now manual - you manually open the vent cover and there is a switch to turn the fan blades on and off. He set it to exhaust mode, can switch to intake mode by changing the wires around which is easily done. But since we live and camp mostly in Michigan, exhaust mode is all we've ever needed.
I intend to get an inexpensive ($28), very lightweight USB ceiling fan on Amazon that will provide cooling intake air should we ever require it. This solution suits us since a new circuit board for the MaxxFan 7500K costs $65 to $85 and will probably be no better than the original.
Hope this is of use to someone!
Cheers,
Annd and Peter
Tselbie
Escape Hatch to MaxxFan
Hello all,
I recently purchased an '87 Scamp 13'.   We are trying to find a way to minimize the Escape Hatch to fit a Maxxfan.  What're your thoughts on this?
TIA
Tracy Selbie
Online
Last seen: 27 min 41 sec ago
Escape Hatch
Hi Tracy,
I've done this a few years back, and you have to shrink the escape hatch down to a 14" standard vent opening. I used a metal plate from the depot that was larger than the escape hatch hole and put wood strip reinforcement inside around the perimeter of the escape hatch opening for the plate to screw into from the top of the roof.
Pulling power over there wasn't a big issue that I remember.
The bigger issue is that you lose the emergency egress point if something were to happen where you can't get to the door which is the purpose of the escape hatch, but I'm not sure too many Scampers could pull themselves through the escape hatch on the roof anyway.
vincentimes.69
Last seen: 1 year 3 days ago
I wouldn't do that. You want
I wouldn't do that. You want to keep your escape hatch so you can... escape!
If for some reason you get caught in a storm and the trailer tilts to its side, blocking the door, well then you're stuck.
I have cut a new opening to install the Maxxair Deluxe fan on my trailer. I left the escape hatch untouched.
2001-16' Scamp
vincentimes.69
I replaced the circuit board
I replaced the circuit board three times on mine. I finally decided to install a 12v-10A voltage regulator and it works fine since. The maxxair fan is well known to be sensitive to voltage above 13.8V. Any spike in voltage will cause it to fail. My power converter itself produces 14.4V so...
2001-16' Scamp
vincentimes.69
2001-16' Scamp
