Roof Fan shuts down with flashing green light and beeping
catdancing0531
catdancing0531's picture
My roof fan has been shutting down randomly with flashing green light and beeping.  (I remove the fuse to get it to stop with the green light.). A while back when this happened there were some bugs stuck in there that stopped it from spinning freely.  Cleaned those out, then it worked fine for a long time. I can't find any obstruction now.  It will run well for a while, then just randomly shut down.  It's happening with increasing frequency.
Anyone else have this problem?  What did you do? Any advice appreciated.
Yep, this may be the problem
Yep, this may be the problem -- See this post:
https://scampowners.com/forums/airxcel-maxxair-green-led-blinking-fix
Haven't had the problem since this repair.
catdancing0531
printed circuit board fix
Thank you! Appreciate all the details. I've contacted Scamp about getting that part.  Mine is no longer under warranty.
peaceandlove
peaceandlove's picture
Last seen: 2 weeks 6 days ago
MaxxAir Fan Beeping and Green Light
Hi Catdancing, we have had the same problem with our 2020 Scamp MaxxAir fan. The remove and re-insert fuse maneuver works, sometimes even on the first try (!) but this is now very tiresome and we are looking to rip out the MaxxAir and replace it with a simpler, less finicky fan.
Anne
Here's how to fix it, ours is
Here's how to fix it, ours is a 2021 but it's probably the same fan: https://scampowners.com/forums/airxcel-maxxair-green-led-blinking-fix
Has worked flawless since...
