adding electric braks to a 13' scamp
PhilipG
apologies if this is listed somewhere: how do I determine what size brakes are need to for a 1990's model scamp 13 footer? any brand or kit type preferred? brake controller? thanks, still helping my buddy put this thing together. great forum!!!
S-13 Brakes
First determine if you have brake flange plates on your axel. Scamp 13's had 2.2 Klb axles with 7" brakes. Eastern Marine in De. sells the 7" Dexter brake backer plates. I think they also carry the 7" brake drums. With a 20 YO trailer you may be better off just replacing the axle with one with brakes.
My question is this:  Why do
My question is this:  Why do you want/need brakes on a 13' Scamp?
PhilipG
because I tow with a 2000
because I tow with a 2000 Jeep wrangler and sometimes I feel a bit "pushed". perosnal choice mainly.
Last seen: 1 day 12 hours ago
Doesn't hurt
You should feel safe when towing anything and while 13's many times aren't equipped with brakes, most times they can be added.  Keep us posted on what you find out.  Eddie's advice above about replacing the axle if it has never been done is sound advice and shows any signs of being at tbe end.  The new axle can then simply be ordered with brakes.
Joe Z
etrailer
This place can answer just about any question you can put to them. I have used them for years and call direct when not sure what i need.
I took the liberty of putting it on the 7" brake link as that is what you probably need but there is so much more as this site has all kinds of tutorials
Joe
Brakes      http://www.etrailer.com/Trailer-Brakes/TruRyde/TRBK-7E-02.html
Drums      http://www.etrailer.com/p-8-257-5UC3-EZ.html
But at about $100 a side it may be better to get a brand new 3500lb axle with brakes which the cheapest place to get that is Redneck Trailer supply which is really top shelf for trailer axles.
http://www.redneck-trailer.com/
http://www.redneck-trailer.com/Portals/4/web_content/files/A.pdf
Joe & Linda
New River, Arizona
2013 Casita SD 17'
