Scamp rewired and full LED
vincentimes.69
Last seen: 1 year 1 month ago
I just finished rewiring my trailer and used this opportunity to go full LED!
List of parts i used:
  • 8ft Heavy Duty 7-way cord with waterproof junction box (installed under the front bunk) - to plug into the car
  • 100ft Heavy Duty 14/12/10 AWG 7-way cord (i used a jokary knife to remove the outer insulation and get individual wires, cheaper that bying separate rolls)
  • LED Optronics taillights 7in with GloLight effect
  • LED 3.9in clearance indicators - 2x red + 2x orange
  • LED license plate lights (acting as screws)
  • Trailer license plate bracket
  • LED bulbs (for inside) 1156 - BA15S
  • LED awning porch light 10" long (white)
  • LED load equalizers Sylvania 15W (for turn signals/stop)
  • Dual USB charger (to replace the cig lighter outlet)
  • LED flood light for reverse (visible under the spare tire cover on the picture) - not required by law but i had reverse lights so...
  • 10A 12V voltage stabilizer for my Maxxair Deluxe fan
  • Progressive Dynamics PD9245 converter
  • Progressive Dynamics PD5000 AC/DC fuse & breaker panel
  • Bunch of WAGO 221-613 connectors
  • Some 25A terminal blocks for the ground connections
  • Some zip ties
  • Lots of heat-shrink tubes
  • Lots of soldering
  • and a few wire terminals
vincentimes.69
The reason i did that is
The reason i did that is because i suddenly lost 12V power during a trip and all my fuses went out. I realized once i got home that some wires had started to melt and most of the crappy OEM splices (little plastic pieces with a metallic jaw inside) were rusted. Repairing a portion of the harness would only buy me some more time. A complete revamp was necessary.
The first challenge was to remove both benches and the table on the back to access the existing wiring.
The second challenge was to understand how Scamp people organized/built this thing. Head scratcher.
I decided to go full Heavy Duty on the wires, even if it's probably unnecessary:
  • Ground 10AWG (white)
  • 12v power 10AWG (black)
  • E-brake lines 12AWG (blue)
  • Everything else 14AWG (reverse, running lights, both turn/stop)
I also decided to install a ground wire for the e-brakes (OEM is using the chassis as the ground).
2001-16' Scamp
vincentimes.69
The only thing i'm not so
The only thing i'm not so happy with, is the color of these license plate lights. Too blue for my taste. But i'll grow over it.
2001-16' Scamp
vincentimes.69
This is the LED light i used
This is the LED light i used for reverse. I bolted it directly onto the steel bumper, in the center so it doesn't interfere with those jacks stored behind the bumper as well. It's a light made for boats, so it's waterproof and stainless steel. I painted the cover in black.
It's super bright and lights up the entire area. Useful when backing up in some sketchy forest camping site. lol.
2001-16' Scamp
herri
Nice job on the trailer
Nice job on the trailer rewiring. Switching everything to LED is a smart move for better lighting and less hassle in the long run. You picked some good parts, and using that heavy-duty wire with the Jokary knife was a clever way to save money. The GloLight taillights, USB charger, and reverse light are useful touches. It’s clear you put in a lot of time and effort, from setting up the fuse panel to making clean ground connections. Must feel good to see everything working smoothly now.
vincentimes.69
Thank you, I appreciate the
Thank you, I appreciate the kind words. Yes, a lot of efforts and, as you said, it feels good now!
2001-16' Scamp
vincentimes.69
I just realized the photos I
I just realized the photos I published in this post aren't visible anymore. Anything I need to do to fix that? Bummer.
2001-16' Scamp
