Scamp Fiberglass Repair in the LA area
dreschool
Hello. Wondering if anybody can recommend a repair shop in the LA area (OC also fine).
I need some fiberglass work done. On a recent trip the tire tread came off the tire and knocked a pretty good size hole in the wheel well.
Also, I may need some work on the door. It seems to been have been fixed by the last owner... looks like the lower hinge bolts ripped out or got loose... he then just added a plate on the outside and inside of the door and bolted it back together... the result is that the door does not stay closed when driving.. I assume this is from it wiggling around and the door catch then passing past the plate that holds it.
Cheers!
