Replacement LED Tail Light vs LED Bulb
Last seen: 3 years 12 months ago
Recently, I decided to replace my Tail Lights with New LED Tail Lights instead of simply replacing the old bulb with an LED bulb.
WOW, What a Difference !!!
These New Replacements are Super Bright and they really look Great with their multiple rows of LEDs. Additionally, they blink better and faster than the old bulbs could.
I chose to replace the tail lights because of the High Visibility and Clarity of the New LED Tail Lights. You simply can't get the brightness, clarity or visibility from using a bluish LED bulb under a Red Lens.
By-the-way, this was not too expensive either.
Here is an example tail light:
https://www.redtrailers.com/ShowItem.asp?id=47-86-101
If that light doesn't work for you, check out
   www.Bargman.com  (select Products)
for other LED Tail Light styles.
