Removing Ensolite/Replacing with Reflectix and Marine Vinyl
Mandy
Hi Everyone,
I'm sure this has been covered, but I'm not seeing it when I search (I'm new here...so I could be doing it wrong). I'm in the middle of removing Ensolite. Most parts come off really easy and the black foam part is powdery and disintegrated. However, some parts are harder to get off. Has anyone found anything to loosen the adhesive without damaging the fiberglass?
My plan is to replace the pieces with Reflectix and marine vinyl with caulk between each piece. I'm tracing each piece of Ensolite as I remove it so I can puzzle it back together. Would that work?
Thanks for your help!
