Added Counter Area
Added Counter Area
I have just finished adding a shelf for more counter area to our 13 Scamp.  We have a stove cover to work on when not using the stove. When using the stove does one make the salad on the bed? We do keep the bed set up. The shelf is removable because it has to be removed to set up the upper bunk. The shelf folds flat for storage.
Last seen: 1 day 3 hours ago
Very Nice
Good solution for a counter extension. Those look like adjustable chair feet from hardware store??  Where did you find the angle scrolls?
Total cost for project?
Shelf
Everything was purchased at our local ACE hardware. Cost was about $30.00. I did have to buy 4 feet of the 3/4" aluminum, used 15" and the 1" aluminum angle, used 12". I will use the leftovers for some other project! The adjustable feet were made up of bumpers, screws, washers, and nuts as the picture shows. The screws were 2" and didn't need to be that long. I plan to cut off the extra length. The two angle aluminum pieces have "Mole Skin" (foot care product) on the side that goes against the cabinet to prevent marring.
Duane M. Rykhus
Duane M. Rykhus's picture
Thums up
Good job !
Have Scamp will travel !
Added to Mod Table of Contents
Nice project and write up. Added to table of contents in the Mod Forum
jpalm
Shelf
Nice job on the new work area.
