Tall tires - what to consider and how to put on?
ktjensen
Would like to put oin the tallest tires possible with minor modifications to a 5th wheeler.  what is suggested?
Lift
Does your trailer have a lift blocks installed at the factory?  Sometime In 2010 Scamp started bolting on their axles. Perfect Casita sells a bolt on lift kit for the Dexter and ALKO axles. http://perfectcasita.com/scdto9axliki.html  A few years ago Scamp started using Lippert axles You will have to verify if the bolt patterns are the same with the Lippert axles. Most people move up to 15" wheels and tires with a lift kit with no issues. The bolt patterns on Scamps are 5x4.5. The best way to see what will fit is to pick up a 15" wheel and tire assy. from Northern or TSC and see if it will fit. Then buy the tires and wheels you want.Once the trailer is lifted expect to replace the single step with a two step set up or carry an extra step platform.
