new door seal
Rhalford
new door seal
anyone replaced the door seal with the new and improved one from scamp??????   if so is the adhesive seem sticky enough?????
Last seen: 3 days 21 hours ago
New seal
I just put it on my Scamp 19 and it is the best thing Scamp has ever done.... I will put up a post shortly on the 19 with how it went down and pic. The adhesive is fantastic, but you can make no errors when you stick it.
Scamp door seal
I had it done at the factory, great addition. The old foam was a joke. It took almost a year for it to settle in and be closed by one hand. It seals extremely well and so worth it.
Here is a picture of the new
Here is a picture of the new type door seal, great improvement
OldPat
Last seen: 9 years 2 days ago
Hinge problem with new door seal
I've installed the new door seal, as well as the latch shim. However, having major problem with the hinges - esp. lower. Door seal adds enough mass to the opening along that edge of the door, that the hinge stresses the fiberglass where the hinge attaches to the Scamp body. Did I do something wrong?
OldPat
Seal
Hey Pat,
I didn't have this issue when I put the new seal on our 97 19 Scamp, but didn't need to shim the latch either, so might be a bit different.
You could try the old bicycle inner tube gasket under the hinge bases on the trailer. Maybe a couple of layers. Take an old inner tube and put the hinge on it and cut out a gasket. Helps prevent water intrusion at the hinges as well.
OldPat
Thanks Greg - I may do that.
Thanks Greg - I may do that. I've used that kind of gasket before...
OldPat
Door seal
The factory replaced my door seal and the tech offered up a thick gasket to place between the lock mechanism and the door striker. Worked great!
randy17440
New door seal
I just installed my new seal.  My weapon of choice for removing the old glue turned out to be a 1/2" wood chisel, wielded with the beveled side down.  You have to be careful of the angle,  but removed 90% of the old stickum in about a half hour.
My door would close, with effort, when I was done.  I shimmed the latch about 1/16", partly to make it easier to close, and partly because I feared that the strong pull in the middle would cause the top and bottom of the door to warp outwards.
It's a vast improvement, and with my first Colorado cold weather trip starting tomorrow, I'm glad I did it.
Randy
Randy in Paonia
