Installing TV and mount through fiberglass wall - 13' Scamp
13 posts / 0 new
Map85086
I have a 13' Scamp with bathroom and shower and I would like to install a TV.  I looked at the pole mount shown in a previous post, but I don't have room for that on my camper.  In a conversation I had with Scamp, I was told I could drill through the fiberglass wall and directly install the TV mount in the wall.  The attached picture shows the area between the rear and side windows where I intend to install the TV mount.
Has anyone done this and is it advisable?  I have the TV mount, which has 2 screw holes.  The TV and mount weigh between 12 and 15 pounds.
Any suggestions or advice will be greatly appreciated.
Thanks,
Marty
Last seen: 2 days 9 hours ago
Shell
I personally wouldn't want any holes drilled through the shell that weren't absolutely necessary. I know folks have reinforced and mounted them to the undersides of the overhead cabinets, or maybe in the closet wall? Would have to see some pics and I don't see any when I edit your post that you uploaded and inserted.
Map85086
Hi Greg,
Maybe I can catch up with you next time you're at the storage.  Mounting the TV with the pole won't work and I don't think I have very good options.
Thanks for responding,
Marty
Martin Prunty
TV
LOL, I wasn't really paying attention to who it was and didn't realize it was you Marty.
I'll just take a look at it for you when we're at storage.... I was there most of the weekend on and off working on the Scamp 19.
Map85086
Greg,
Greg,
I'll look you up if you are going to be there this weekend.
Thanks,
Marty
Martin Prunty
Stratoguy
TV install
If you use the search section near the top of the login page, you can search for previous tv install suggestions by members as well as photos. Take a look there under tv install. I think there are better install options shown there.
SG
Stratoguy
Link
I went to the link to the previous discussions on adding TVs to the Scamp and found the correct thread and copied that link to post here.  It is:
adding 12V 15" TV to 13' Scamp
if you can find this discussion thread through the search tool, it will provide you with many alternatives for installation.
SG
Map85086
Thank you for your help.
Martin Prunty
Table of contents
Another route is to check the table of contents that are at the top of the modifications and maintenance section.
http://www.scampowners.com/forums/index-trailer-modifications-forum
The TV posts are listed there.
Last seen: 3 months 1 day ago
TV Mount
I think you could mount the TV bracket just about anywhere, like onto the rear cabinet, as long as you take the TV off the bracket while traveling. It's the weight of the TV, which would be multiplied greatly when going over bumps that would cause problems.
Map85086
Thank you.  I've decided to
Thank you.  I've decided to mount the TV under the rear cabinet.  I think your advice to remove the TV from the mount before traveling is advisable.
Martin Prunty
