Help! Fitting two adults on the 44" wide bed
13 posts / 0 new
In the past, we used sleeping
In the past, we used sleeping bags: two differing weights that zipped together = double wide.  If it was cold, we put the heavier weight on top; if warmer, the lighter weight.
We now use regular bedding, incl. sheets!  If you look at the photos in #7 above, you will see fat red pillows on each bed.  This are large pillow covers, and contain all the bedding needed for each bed.  Our interior colors (in this older SCAMP) are red, white and green, so they coordinate with our decorating scheme.  They are simply left out during the day: one in the space behind the kitchen counter at the front; the other, in one of corners at the back of the trailer.
You will also see in the photos on each bed a red blanket: we have three; they are polartec; they are draped over each of the couches when the SCAMP is parked, to minimize sun fading of the couches.
What sized trailer ? We have
What sized trailer ? We have the 16 foot model with the side dinette. I sleep on the big bed and my bride Takes the side dinette bed. Just makes it easier when one has that 3:00 a.m. potty call!  Works out just great!
