88 Scamp Starting Rebuild
24 posts / 0 new
keepontrying
keepontrying's picture
Just picked up an 88 16 ft Scamp that has been sitting in a field for over 10 years , in rainy western washington concerned about taking moss off the exterior I have used pressure washing in the past on aluminum trailer restorations , on the scamp I am hoping to preserve the original gel coat finish without damaging it . Is pressure washing a good way to go before hand washing and waxing it ?
Steve and Sandy
Cleaning up project trailers.
I use Jomax house cleaner and bleach (read directions) let it sit a while and then brush off. After you get it cleaned up let it set in the sun for a while and the white will brighten it up. I do not use a pressure washer. Jomax is made for removing mold, moss and crud. Found in big box stores.
keepontrying
Hi Eddie ,
thanks for the information I will try that and see how it works .
Steve and Sandy
Steve and Sandy
1998 Scamp 16 Ft Deluxe
1973 Boler 13 Ft project
2000 Ford Expedition
Anacortes ( Guemes Island )
Washington
Last seen: 1 week 21 hours ago
Need moss covered pics
Need moss covered before and after pics.  laugh
We don't have moss in AZ....
keepontrying
Photos
I have the before pictures waiting to scrub off the moss when weather gets better will post both before and after pictures than .
Steve and Sandy
Washington
I recommend against using
I recommend against using pressure washer: can cause damage.   The best general approach is to start with something mild, and then work up to something stronger.  It is important to "do no harm."
I would try using Scrubbly Bubbly (or the like). I have used this in a number of situations: typically, it did the job, and did no damage.  A soft brush (note the use of the descriptive "soft) may also prove helpful.
Speaking of a "Soft Brush"
Sams Club has a car/truck washing brush that is AWESOME !!!
The brush is a Pole Brush and the bristles are designed for washing cars and trucks.
I can wash my full size van in about 20 minutes.
You can attach a hose to the brush, but I never have, I simply fill a bucket with "TurtleWax Ice" carwash and water and scrub the van with the sudsy brush.
By the way, TurtleWax Ice is also an AWESOME product, I love it !!
I agree with Mccownw start with a mild soap (like TurtleWax Ice) first, and then move to the harsher chemicals later.
I have used Jomax and it is like using concentrated Bleach, it will bleach out anything it gets on (be sure to wear goggles if you use this stuff !!! ).
If your gel coat is in fairly good condition ( ?????? ), or any condition at all, the carwash and brush should get 90% of the crud off.
I have attached a picture from Sam's Club's website of the Carwash Brush.
This carwash brush is also available from Amazon at...
Hayco - 7 pc. Car Cleaning Brush Set
Good Luck !!
keepontrying
Soft Brush
Thanks for the info I will definitely be using one of those brushes for the Scamp as well as my van
Thanks again
Steve
Steve and Sandy
Washington
keepontrying
Progress of our 88 Scamp restoration cont
Well on friday we actually had some sunshine and a break in our weather and were able to scrubb the scamp from top to bottom thanks to the help of my son . On saturday I removed the cushions , curtaims and cabinet doors and filled up 3 garbage cans of lets just say some undesirable debris . next on my restoration list I will be removing  the rotting wiring , plumbing, fresh water holding tank and  some of the cabinets I will be getting back to some more of the exterior work later in the restoration process . I will be updating you all with my progress as we continue along this journey of the scamp restoration .
unfortunately we were only able to post a before picture at this time seem to be having some difficulties with posting pics on here...:(
Steve and Sandy
Washington
Swamp Thing
Wow!  There was an oldie horror flick called the Swamp Thing and that was the first thing that came to mind.  Can't wait to watch you bring this gem back.
keepontrying
88 Scamp after first washing
This is after its first washing there is a scamp underneath all that moss and dirt ......smiley
Steve and Sandy
Washington
