Toilet Tank Leaking at Base
JenConway
JenConway's picture
Hello Everyone,
The base of the tank that my toilet sits on is leaking. Water appears to be coming in on the front right corner (if you're sitting on it) where the tank meets the floor.
From what I can tell (through online research escapades), the tank sits on a wax seal ring and is screwed to the floor. My current plan of attack to address the leak is to disconnect the water, unscrew the tank, replace the ring, and screw the tank back on. Does anyone have experience with this type of leak? Or corrections for the underlying toilet assembly?
I have attached pictures of the leak. My Scamp is a 16ft 2007, layout 5 (front bathroom/wet room).
John2R
John2R's picture
Last seen: 6 months 3 days ago
Any updates to this? Were you
Any updates to this? Were you able to remove the tank and replace the wax ring?
1991 Scamp 19’
workthatwedo
Same issue for me on my 2000
Same issue for me on my 2000 16ft standard.  getting ready to pull the whole thing out and see, has anyone done this?
John2R
John2R's picture
@workthatwedo
@workthatwedo - Yes, I pulled my tank earlier this year. I discovered that the wax ring is for keeping water from the shower from going out the hole in the floor where the black tank dumps. The underside of the tank is one piece.
It ended not being a leak from the bottom, but a leak from the top.
1991 Scamp 19’
