propane fridge
Rhalford
Last seen: 11 months 2 days ago
propane fridge
anyone know about how long a tank of propane will run just the refridgerator only  thanks
Last seen: 3 weeks 4 days ago
This is only a guess, but I
This is only a guess, but I would say ten days to two weeks. We use about one tank a week, but that includes hot water (used sparingly) and a little bit of heat in the morning on the spring/fall trips.
another component
As stated 10 days two weeks sounds logical and is affected by ambient temps. hen very warm/hot out the Burner can run nearly non stop on the smart larger fridges ( 16 and 19's) and on the 13 foot Scamps the burner is adjusted to meet the cooling needs so in cool weather a low flame and hot weather a larger flame. might influence your run time
Solari
I've gotten nearly a month on
I've gotten nearly a month on propane on the lowest setting  lately while boondocking out west. It's been cool days and cold nights so that helps. I also use the stove a couple times a day.
Ray
Gompka
Last seen: 2 years 4 days ago
A month sounds about right, I
A month sounds about right, I use less than one tank a year using mostly the fridge with very occasional stove use.
Terranovafox
Terranovafox's picture
Propane Fridge: Looking for pic of Directions Label inside door
Hi, all.  We own a 2010 Scamp 16' Deluxe, plan B.  Inside the fridge (Dometic Model # RM2410-2RX) there looks like there was a quick reference directions label on how to use the fridge.  Almost all the writing has been ? wiped away.  Would anyone have a picture of the label that they would be willing to share, please?  Dometic says the label (directions sticker) is not a replaceable part. I'll print and laminate it before I put it in the fridge.
Thanks in Advance.
Paul
Paul Barrett
This label?
You probably mean this label. I hope it is legible. (I deleted  the picture.)
Now I am playing...
Now I am playing with uploading a picture by parts. (Also deleted those.)
Try again...
Try the  original size.
