propane fridge
Rhalford
Last seen: 2 weeks 7 hours ago
propane fridge
anyone know about how long a tank of propane will run just the refridgerator only  thanks
Last seen: 14 hours 6 min ago
This is only a guess, but I
This is only a guess, but I would say ten days to two weeks. We use about one tank a week, but that includes hot water (used sparingly) and a little bit of heat in the morning on the spring/fall trips.
Tacoma, Double Cab, 6 cyl. 4WD
Last seen: 12 hours 5 min ago
another component
As stated 10 days two weeks sounds logical and is affected by ambient temps. hen very warm/hot out the Burner can run nearly non stop on the smart larger fridges ( 16 and 19's) and on the 13 foot Scamps the burner is adjusted to meet the cooling needs so in cool weather a low flame and hot weather a larger flame. might influence your run time
