How to clean/renew exterior
asfizer
I recently bought a 2013 13'. It's in fairly good condition overall, but it looks like the exterior though not damaged it's just not as white as it should or could be. I used a power polisher with Maguiar's M6732 Marine/RV One Step Compound, it helped a lot but it isn't as while as I hoped it would be. It did remove the gritty oxidation from the surface however. Any suggestions? Or did I just didn't do a good job with what I used?
DPS
DPS's picture
Exterior polishing
I have had satisfactory results with Presta Gel Coat Compound Part no. 138532 which I learned about on a Utube channel called "That Boat Guy".  Good luck!
Doug
catdancing0531
catdancing0531's picture
LA's Totally Awesome All Purpose Cleaner
Try the Awesome cleaner.  I had black streaks on my Scamp and it worked really well. Spray it on, wipe it off.  Very easy.  My Scamp had become a dingy white and this seemed to brighten it up.  About $1.00 at one of the Dollar stores.  Dilute as recommended.
