How to make a Scamp 16ft side dinette crib? Help please.
MN Scampers
We need to get some ideas  on how to make a 16ft scamp side dinette crib.
Last seen: 4 days 1 hour ago
Crib
Looks like you stumped the band.
I would use 3/4 pvc pipe and joints all kinds of which are available at HD or similar. My thoughts would be to put the bed down on the side dinette and then custom build with the pvc so that it fits right in there but can be removed to return the dinette to normal use...
You could easily fashion some type of securing system so that it would not accidentally come out, but would be simple to remove later or when not using it.
This is an example of a pvc pipe bunk bed I did to give you some ideas. Removed it later when it was time to sell and trailer was right back in original condition.
