Winter heating while Boondocking
17 posts / 0 new
ammaspatrice
This is really helpful,
This is really helpful, Sunfish! I appreciate the advice and helping me understand venting.
I have worn earplugs at home, so I guess it's time to either wear them in the Scamp or get used to it where I don't hear it :)
Patrice Mott
the scamp heater doesn't use
the scamp heater doesn't use a lot of propane, i was camping in 32 degree weather for 4 days and 4 nights with the heater running continuously, i used 1 full tank of propane.  loud? again i don't experience that, the ambient noise is helpful to keeping everyone asleep and hiding the noisy neighbors (if there are some).  i love the stock scamp heater.
ammaspatrice
Great info! Thank you .......
Great info! Thank you .........can I ask how you keep the battery going for that length of time?
Do you charge it while driving, or use a solar panel? I am also wondering if, in a pinch, I can hook up the trailer to the vehicle and charge the battery for an hour or so while eating dinner, etc, before bed. Would that charge it enough for a night's use of the heater?
Patrice Mott
i was hooked up to electric
i was hooked up to electric during that time, my apologies i didn't realize this was in regards to boondocking.  yeah solar or another battery might be a good idea.  if you're not in the camper during the day just shutting off the furnace/other electronics/lights/water pump will probably save you some juice too.
Based on the 91,500 Btu per gallon and 4.5 gal in a 20 lb tank you should get around 20 Hrs actual burn/run time  from a completely full 20 lb tank this as a little conservative for safety reasons.  We only have one tank on our 13 so if run low it would need to be taken to a fill station.  This should be several days of heated comfort as long as the House battery is kept charged.
ammaspatrice
Thank you Saluki!  You
Thank you Saluki!  You Scampers are all AWESOME !!!!!!
Patrice Mott
