Converter unplugs from electrical panel
LyleB
Last seen: 4 years 12 months ago
Has anyone come up with a relatively simple way to keep the converter plug from falling out of the electrical panel socket? This is a very annoying problem that happens regularly. The way my Scamp 16 Layout 4 is built, it requires me to remove the electrical panel each time to plug it back in. I know the 5 screws that must be removed each time will soon stop holding. Seems like this is a common problem and there should be a reasonable solution.
Furrion FCKIT-30 PLUG
On mine it was easy to lift the cover under the seat and plug it back in. But I and many others have changed to a boat type plug on the cord, yet others have tied it in, one owner built a “box” for the cord to rest in.
HiLo
Plug comes out
I bent the blades on the plug. Hasn't come out since I did that a few years ago. But I still check it now and then.
Luxus panzer
A quick zap strap worked for
A quick zap strap worked for me.
