Advice on painting standard cabinets
Ann B
I'm updating the 2000 16' (Standard Layout 4) I recently purchased. Do I need to treat or sand them? Any other advice will be greatly appreciated!  Thanks in advance.
Last seen: 12 hours 16 min ago
Cabinets
The fiberglass cabinets will need a bit of sanding and Marine paint will probably be what you’d need to use on them. Best to use a small roller to apply marine paint.
Ann B
Cabinet doors
I want to paint the fake wood cabinet doors. Not the white fiberglass frames.
Maximum Fun Time!
Paint doors
Ah, that’s much easier. wink
I would’t sand them as the fronts are a glued paper type laminate. You should be able to clean them well, then just use a good primer. Most any interior paint could be used to paint the cabinet doors.
LyleB
I painted mine a few years
I painted mine a few years ago. Just removed them, removed all the hardware then primed twice with a good quality primer. After that two coats of your choice of enamel and they were good to go. Re-installed with all new hardware and knobs. Made a great improvement and never had any problem with any paint chipping.
Ann B
I cleaned them all and bought the primer and paint.  I'm ready to go. Thanks for the help!
Maximum Fun Time!
Eric1028
How are they holding up? Can
How are they holding up? Can you post a picture of them?
Eric Yantis
