Emergency breakaway brake kit
kwombat
kwombat's picture
Last seen: 7 years 3 weeks ago
I have seen the subject mentioned before  Any suggestions on preferred brands?  We have a 16 ft 2016 Deluxe
Ken & Ellen Peterson
Emergency breakaway switch
It’s my understanding that it is just a switch and lanyard. Pull the lanyard and the 12volts from the Scamp battery is applied to the brakes.   I plan to do it but have not yet looked for a clean weather proof way to wire it. I'll just get a switch from one of the many dealers in my area.
Last seen: 1 day 2 min ago
Breakaway switch
Good selection, not expensive. The Tekonshah one should be a decent one.
Breakaway Switch
JTST_Scamper
Our Kit
CURT 52041 Soft-Trac 1 Breakaway Kit
This one has no charger for the battery in the box.(You might be able to get an optional charger.)
In reading various posts on the topic some utilized the trailers battery and others took a stricter view on what was required to satisfy legal requirements in having a separate battery. The cost is minimal and checking a 2nd battery isn't much trouble.
Second battery
I doubt that the law can require a separate battery when a breakaway switch is not required. Scamp will not even put a breakaway switch on if you pay for it. I tried. Small trailers kill people also.
JTST_Scamper
Info
Here is some info I found on the web when I was doing my research. Not trying to start a long discussion on the topic but found it interesting to read.
http://drivinglaws.aaa.com/tag/trailer-brakes/
Break Away
My concern with breakaway on my 13 scamp is that there is only one 3/8th inch grade 5 bolt holding both safety chains. I'm sure one good sharp yank on that bolt by a 2,000 LB trailer would snap it off! I have replaced the original grade 5 bolt with a grade 8 bolt. I am trying to dream up a good way to attach the two chains separately. When I do I will post it. Also, I use shackles instead of the supplied "S" hooks to attach the safety chains to the TV. I just don't trust those "S" hooks to stay on!
Tioga George
Tioga George's picture
DuraSafe Coupler Protect
I've been using DuraSafe Coupler Protect  to prevent unhitching [decoupling]. Here is a URL to the Coupler Protect.
https://durasafelocks.com/product/coupler-protect/
George
JTST_Scamper
Same Here
Love the DuraSafe product.......
We added this product to our hitch setup as well
