Remove roof AC and instal Maxxfan?
nakizo
Hello.
I have a 2004 13' Scamp with an AC unit on the roof. I live in the PNW and never use the AC. It has recently started leaking.
I was wondering if anyone has removed their roof AC and installed a Maxxfan in it's place or if anyone can offer any tips about this.
Update: I removed the AC unit and installed a Maxxfan. It fits perfect.
Last seen: 1 year 1 month ago
A/C leak / Fan conversion
LEAK: If you remove the inside A/C cover you will see 4 larger screws and nuts. If you tighten the nuts you will put more pressure on the A/C base gasket, a lot of times stopping the leak. If that does not work the next step is to replace the A/C base gasket. This is for a leak when not operating. If you have a leak only during operation it is a condensation leak. You will have to open up the top get to your evaporator coil and clean your coil and drain.
Fan Replacement: The A/C opening is usually the same (14"x14") as required by the fan. Your A/C uses 115VAC and your fan will use 12VDC, You will have to adapt your wiring to carry the different voltage.
NOTE: Be careful  on tightening the A/C inside cover screws. If you over torque them you can break through the roof.
jkalyn
jkalyn's picture
AC removal
Does anyone know if nakizo was successful in removing the AC and installing a fan? I posted the same question about AC removal in 2021 and did not receive a reply as far as I know. I already have a FantasticFan so would just like to put in a skylight, but was afraid of creating leaks.
James
