Replacing door seal on Scamp 19
jpalm
We're considering replacing the door seal on our Scamp 19'. I've seen comments about having to add a shim when doing this.  Where does this shim go?  Does Scamp provide it?  Any pictures available?  With a new seal can you close the door without using a shim?  Thanks for any info provided.
Last seen: 1 day 17 hours ago
New Seal
On my 97 19 Scamp I put the new door seal being sold by Scamp Trailers. Can't rave about it enough, it is finally a good solution. I did not have to shim, but some do. It was tight at first, but is fairly normal operation now after being on the trailer for 6+ months. If you do have to shim, it would be adding washer(s) under the lock on the interior of the door so the door latch will catch.
kilovictor
kilovictor's picture
Last seen: 6 months 6 days ago
16 Door Seal
I replaced the seal on my 2013 16 STD this spring. I did not use a shim. It is tight but getting easier as time goes by and temperature goes up. The only hard thing about it was removing the adhesive that held the old seal on.
KVJ
