Replacing door seal on Scamp 19
jpalm
We're considering replacing the door seal on our Scamp 19'. I've seen comments about having to add a shim when doing this.  Where does this shim go?  Does Scamp provide it?  Any pictures available?  With a new seal can you close the door without using a shim?  Thanks for any info provided.
New Seal
On my 97 19 Scamp I put the new door seal being sold by Scamp Trailers. Can't rave about it enough, it is finally a good solution. I did not have to shim, but some do. It was tight at first, but is fairly normal operation now after being on the trailer for 6+ months. If you do have to shim, it would be adding washer(s) under the lock on the interior of the door so the door latch will catch.
kilovictor
kilovictor's picture
16 Door Seal
I replaced the seal on my 2013 16 STD this spring. I did not use a shim. It is tight but getting easier as time goes by and temperature goes up. The only hard thing about it was removing the adhesive that held the old seal on.
KVJ
