Progressive charge wizard.
mk evenson
mk evenson's picture
Last seen: 5 years 3 weeks ago
Seems like the Progressive Charge Wizard does the same as the Battery Minder 1510. Perhaps with the advantage that is is plugged in to the charging system. I was wondering if folks are adding the Charge Wizard to new Scamps from the beginning, ie when taking delivery?
Mark
P.S. Just heard from Micah at Scamp, the Charge Wizard is now included on all NEW Scamps.
PD 9130
 Scamp does not install the charge wizard. It  cost about $30 and just plugs into the converter. I did not mount the pendant. I laid it inside a cabinet door. I just let the pendant hang out the door while the trailer was in storage when I wanted to monitor what it was doing. The pendant indicates it's mode by flashing lights. It's very hard to sleep with the flashing LED's in the cabin.
