Loose black water pipe
KeithG
Hi, the black water pipe and valve on my 2022 (16' Layout 6) appears to be a little loose. Upon returning home from the Rally, I noticed that it seemed as if it had rotated. With a little pressue I was able to swivel it with my hands. I'm concerned if there is a seal that has broken.
Any suggestions? I've attached a photo.
Last seen: 10 hours 31 min ago
Black tank pipe
I'm not sure what Scamp is currently using, but some types are movable. If the movable type is adjusted much it can cause the seals to begin leaking. The big question, is it leaking?
