Fresh water tank petcock valve connection
Jaebyrd357
I recently tried to winterize my water system. When I went to drain the fresh water tank, I noticed the petcock valve wasn’t connected to the drain hole. I can look directly to the ground from inside the trailer. Is the valve supposed to be attached or did it just shift in motion and I didn’t notice it before? It seems like there should be a more substantial connection other than just a hole in the ground! I’m not sure what to do.
Yes, it had a hose on it from the factory.
