Bunk Beds
GraminScamp
Bunk Beds
I just bought a 1981 13 Scamp, I would like to know how to find  link to add a bunk to my  camper.
Last seen: 2 days 19 hours ago
Bunk
Welcome, and congrats on the new to you Scamp
You should have the bunks unless someone modified it. Your front sofa converts to bunks.
A bit more explanation on what you are wanting?
GraminScamp
No bunk
There is only a single bottom, and a lip to install a top bunk.
  Thank you.
Katy L
81 Bunk
Ah, someone modified it. surprise
Here is a pic from my previous 1981 Scamp 13 showing the three cushion pieces you'd need to put it back stock.
You need the bottom cushion, back cushion, and the banana cushion. Scamp Trailers parts dept should still stock these and should fit a 1981. The back cushion is attached to the wood block via a piano hinge the full width of the block. There are 2 chrome pole bases and 2 chrome poles which can probably still be ordered from Scamp Trailers as well. You can see the chrome pole bases in this pic of the base unit of the sofa.
I would call the Scamp Parts department and discuss with them the parts you'd need to have shipped out and what it will all cost.
The other alternative, if you wanted a permanent bunk setup would be to modify your own bunks. This is a 3/4" PVC bunk bed I fashioned in a different trailer, but the idea could come across to your situation.
RocheACri woods
RocheACri woods's picture
Video of bunk in action
Greg's pictures (and wisdom) are probably your best help, but Scamp does have a video on their website called Beds and Bunks that shows the bunk in action if that could give you an even clearer visual on how it works.  https://www.scamptrailers.com/helpful-videos.html
Good luck with the project!
GraminScamp
Thank You
Thank you for the videos and advice.
Katy L
Bunk info
