Hot water not running
TLS
I have a 2010 16' that we just purchased.
As we're working through getting it cleaned up flushing the water system, it had been in storage for the last 3-4 years, hot water does not flow from the kitchen faucet or shower.  When we bought it and towed it home I noticed that water and wet paper looking debris was coming out of the external drain plug on the hot water tank.   Yes it was off when we were driving. I've tried flushing the system and did some reading on the Atwood hot water heaters.  Online people are reporting that the check valve on them can plug up on the hot water exit.  I removed the the 90 deg fitting to find that it is not a check valve but with that off and with a cleaning wand I started to run a lot of water through the tank with the drain open..,   I'm getting a lot of debris from the drain, it looks like wet pieces of paper, some clear to grey slime.   While i had the hot water line off the tank I've blown out the faucet and shower lines with my air compressor and will flush them out with fresh water before I hook the line back up to the tank.
I would love to hear your thoughts on cleaning out the tank so we can start using it.     the one thing I can't confirm is if the cold water supply line has a check valve on it.   Does anyone know if scamp plumbs their water systems with check valves?
thanks for the read looking forward to your thoughts...
TLS
after doing some more
after doing some more research here's what I found from Atwood
http://www.askforatwood.com/images/WaterHeaterServiceTri-Fold.pdf
Last seen: 1 week 5 days ago
Water heater flow
It is a flow problem with hot only? No bypass valves?
TLS
Yes hot side only,  I spent a
Yes hot side only,  I spent a couple hours cleaning the tank out and finally cut out the bypass valve on the fill side of the tank.   That was the problem.  The handle would turn but the ball would not it was stuck closed, so no ability to fill the tank or get any flow out of the hot water side of the taps.... the tank was filthy a lot of crap came out of it.  I removed the pressure relief valve and added some vinegar as a final step.   Tomorrow I'll run some bleach through the fresh water system and then see if I can get the burner to light and get the fridge running on propane.     Then we'll be ready to go...
Last seen: 1 year 1 month ago
Aluminum tank
Atwood uses an aluminum tank and vinegar could damage the tank. It helps to pull the tire on the other side up on a couple of blocks to help flush out the tank.
TLS
Eddie,
Eddie,
Atwood actually recommends cleaning with vinegar, see picture from the link above....
Learned something new
Learned something new about the Atwood WH. On a Boy Scout camping trip I filled my aluminum canteen with Kool Aid. When I got to camp my canteen was empty. The Kool Aid had pitted and eaten a hole in my canteen. I try to keep any acid based liquid away from aluminum after that incident.
Thanks Eddie
