Part Number
EugeneFlorida
EugeneFlorida's picture
Last seen: 7 years 3 weeks ago
Part Number
2016 13ft scamp:
anyone Know the axle grease seal Part  number?
Scamp Parts
Go to Scamp Parts/ Running Gear. Click on the product description of the bearings seals and races. They state which one fits which trailer. If you have a 80's or earlier trailer with the light weight axles they are different.
More seal info.
With Easy Lube axles you want to specify double lip seals. Scamp, E-Trailer and trailer maintenance places sell them. If you take the seal part numbers to a discount auto store you will more than likely get a single lip seal. Not a good thing for trailer brakes .
The Dexter P/N looks like 010-060-00. http://l.b5z.net/i/u/6149609/f/Seal_CR.pdf
More Seal info. 2
10-60 also works but you must make sure it is double lip for EZ Lube hubs.
I'm pretty sure this is it. Watch the video.
https://www.etrailer.com/Trailer-Bearings-Races-Seals/TruRyde/RG06-020.html
EugeneFlorida
thanks for the help
thanks for the help
this is what I ordered
