Scamp Specific Tools ??
31 posts / 0 new
bcsnave
bcsnave's picture
Most IMPORTANT.....
Have your insurance card with Flatbed towing...
I smile when I read what people pack for tools......some sound like they are taking their roll away MAC toolbox with them.
I do a lot of maintenance myself...but changing a spindle on the side on an interstate...not my cup of tea...I can do it certainly but I have seen many of accidents with inattentive drivers side swiping...
Get it off the highway ....let someone else do it..
mk evenson
mk evenson's picture
Scamp tools
Thanks, just the post I need!
Mark
Last seen: 1 month 1 week ago
Spare Tire Wrench
On our 2015 13' Scamp the studs that the spare tire is mounted on are too long. The nuts are the same size as the wheel lug nuts but because the studs are too long a regular lug wrench will not work to get the spare tire off the back of the trailer. You will need a deep socket ( I think 13/16") and something to turn it with like a breaker bar or ratchet. I can't understand why Scamp uses those studs that are too long. Just plain DUMB!!!!
Last seen: 41 min ago
Spare Tire
I haven't had a newer Scamp, but the three Scamps I've had 81,96 Scamp 13 and my current Scamp 19 all have been the correct length and I can remove the spare with a lug wrench. Is this something they've changed?? Is the lug depth adjustable? Can they be turned in the mount and the depth adjusted or are they fixed and too long? Interested to hear more folks weigh in on this one, cause that isn't the way they should be doing it.
Last seen: 3 days 8 hours ago
studs are too long
I thought that each bolt had three nuts in it. One to hold the mount to the RV, one to space the tire away from the body, and one to hold the tire on. If so, just turn the 2nd nut closer to the end of the bolt.
On the spare, the nuts would
On the spare, the nuts need not be so tight that it would require a breaker bar to loosen them (tight, but not that tight!).  I suggest using a large adjustable wrench to break them loose; once loosened, on the spare you should be able to spin them off by hand. Another option would be to place a larger nut on the stud behind your lug nut, as a bushing or spacer, and tighten your lug against them.
Great idea
Putting backing nuts is an excellent approach. The depth could be set perfectly with that setup and changed if rims are changed and require a different setting.
Spare Mounting
ecOgv is right. Number 2 nut could be moved out to shorten the outer end of the stud. But doing that would move the spare tire away from the camper body. That would reduce its support. Holding the tire tight against the body helps support it and keep it from shaking as much. Spacers or extra nuts would create the same problem.
I do not like the idea of not tightening the nuts. There is a whole lot of shaking going on back there and while traveling you have no way to see if the tire is okay.
Spare tire bolts again
Good point. I carry a full tool box but for others, how about  long nuts ( there a a couple of kinds) or just cutting the bolts shorter?
Last seen: 3 months 6 days ago
Spare tire support
My spare tire used to be tight against the outside wall, but it was one of the places that collected dust and grit and also the tire cover would not go on well. Now I keep it about 1/2 inch away from the wall by adjusting the holding nuts appropriately. To support its weight I made a pair of wedges (wood) that slide over the bumper and fill the space between the bumper and the tire. These wedges are pulled together by a bungee cord. The three bolts hold the tire to the Scamp wall, but don't support its weight.
