Curtain rods always falling
prairieboy
Last seen: 2 years 2 days ago
Any suggestions to keep curtain rods from falling. I've bent the clips but I'm hoping for a more creative solution.  Thanks.
Cheap and easy fix
I bought a bag of rubber bands and used really small ones criss-crossed on the rod on both sides of the bracket.  You really can't see them and they are easy to take off when the curtains eventually need washing.
Rhonda Riebow
Last seen: 1 year 1 month ago
White plastic wire ties
Walmart sells some small plastic wire ties in the Hwd. section. Zip tie the rod in the holder, then use a set of small wire cutters if you ever want to remove the rod.
https://www.walmart.com/ip/Monoprice-Cable-Tie-4-inch-18LBS-100pcs-Pack-...
mspgaff
mspgaff's picture
Curtain Rods
I've tried numerous methods, but the rubber bands is currently doing a good job.   Think of yourself as on the space station, they tie everything down also. LOL This is not limited just to Scamps, we have friends with other trailers. same issue for many.
