FYI for a furnace failure
jpalm
On first day of a fall camping trip our Scamp 19 furnace failed to ignite.  We eventually found the cause was a malfunctioning propane regulator which didn't deliver enough pressure to allow the furnace to fire up (which was a documented possible cause in the Suburban furnace manual, but not an intuitive cause).  A new regulator has fixed the problem.
Last seen: 4 days 15 hours ago
I'm currently working on the same issue on mine, but haven't gotten that deep into it yet.
I will definitely take a look at that, since it's one of the easy solutions.....  Glad you got yours firing.
