5th wheel
Mussy
Last seen: 10 years 2 weeks ago
5th wheel
Can a f 150 4x4 tow a 19 ft 5th wheel?
Absolutely
Absolutely
Online
Last seen: 7 min 39 sec ago
Anyone run into any side
Anyone run into any side clearance issues with the F-150 towing the Scamp 19? I know some of the newer trucks require a higher clearance and lift kit on the Scamp.
Mussy
Yea you have to lift the axel
Yea you have to lift the axel by 3 inches on the scamp
Mussy
towing
does anyone know of anyone who has a fifth  wheel who could pull our scamp to rv lot?  In  massachusetts
Online
I needed to do the same thing
I needed to do the same thing Mussy when I bought our Scamp 19 last year. I was fortunate to find an SOI member close by that was able to do it for me. Hopefully, you'll have the same luck. I did check with local towing companies and most all towing companies can flatbed the Scamp 19. If the distance isn't too great it might be worth a call to some of your local towing companies and explain what you're needing.
Keith
Same here. We bought ours
Same here. We bought ours before we realized how different they are. I tried to use an online towing service, but the ball size was an issue. One guy thought he may be able to flatbed it, but by then I had found a truck I could mount the hitch in. The seller had the hitch, but had wrecked their truck recently. I was lucky that the person I bought it from was very patient.
Mussy
5th wheel
Do you still have your fifth wheel and what do you tow it with?
Keith
Yes. We are still renovating
Yes. We are still renovating it, but we towed it once for about 250 miles with a v6 F-150 2wd. No problems.
I am not aware of any current truck that couldn't handle a scamp 19, but I'd probably not want to live with a 4 cyl pulling one around. Others around here will have more experience actually pulling one, but the prior owners of ours pulled it with an s-10 and then a sierra. I believe v-6 and v-8 respectively, but I'm not certain. They put 13k miles on it.
